Pulling to the right
Jerigorn
Decatur, IL
I'll make this quick. On my 09' i installed bilsteins at either 2.1 or 2.5. Can't remember which. I slapped on some kanati mud hogs and took it to get aligned. After a while I noticed it was pulling slightly to the right. Eventually I get the alignment done again. Technician said it wasnt too bad. Now...2 alignments done and it is still pulling to the right. I keep up with my tire rotation and that seems to be the oddest part about it all. Whenever I rotate my tires, the pull gets better, but eventually goes back to pulling right. When they are rotated, they stay on that same side of the truck. The crown of the road is not the issue, it happens on both sides. Any suggestions?
SilverStreak88
Houston, Texas
5.7 Eco Gasser
You should check your Bil on the right side and if it might be set lower than the left. Check all your steering components and see if anything has slop.
huntergreen
Marine Corps Navy Badge
agree, make sure they are both set at the same ht.
