Question
DURASPANK
Greenville,SC
Does the Mopar SRT filter for the 6.4 fit the 5.7? Fixin to make a online order .
Burla
2010 Hemi Reg Cab 4x4
someone call
It's the same, but I don't know if srt is the large or small filter, and I don't know that they have the large option if you wanted it,maybe they do. If you search an old srt filter like for a 2010 ram 1500, that will fit and will be a little larger. The 6.4 ram hemi is different then the srt hemi despite identical torque and hp numbers, but the srt filters fit for sure.
@U&A the larger filter fits yes?? I know the smaller srt filter 5.7 does, and likely the larger one will if they have one.
Royal Purple 20-820 would work and is large filter. You could look up specs and see size.
royal purple 10-48 small filter..
Outside Diameter : 2.98 [75mm]
Height: : 3.40 [86mm
larger filter 20-820
Outside Diameter : 3.65 [93mm]
Height: : 3.75 [95mm]
