Ram 1500 abs or not
Bigleroy
Mt Joy pa
Hey guys, I am really baffled here. I'm working on my neighbors 2007 ram 1500 and the front wheel bearing is bad, it is the left front, and it is the only wheel on the truck that has a wire going to it. It appears to have abs because it appears there is an ABS pump up near the master cylinder. But it seems odd to me that there's no wires to any other Wheels. Any ideas?
RamDiver
Marlborough, Ontario Canada
2021 DS
And, welcome.gif to Ram Forum. :cool:
62Blazer
Midwest
The sensor for the rear is probably located on the diff, on the top of the housing. It's not independent 4 wheel ABS, just front and rear. When ABS first came out it was common for only the rear tires to have it, and it was a single sensor that just said if the rear wheels were locked up or not by sensing the ring gear/diff speed.
