RAM Dash & Front Doors Speakers Combination
Pollux
Jacksonville, FL
I’m going to replace the front doors speakers in my RAM with a set of JL 6.5” component. In the dash I got a set of the JL 3.5” with bass blockers. Theoretically speaking, will this combination of dash and door speakers work? Or I have to either eliminate the dash speakers or the tweeter in the 6.5” set? These are going to be amplified with the enclosed passive crossover for the 6.5”. I see that this combination will double the tweeters and I’m wondering if that is a problem. I already got the parts just waiting for some time off to get them in.
Thanks!!!
adrianp89
Tampa Bay, FL
It will work but you will cut your power to the components in half, and it will not sound that great even with power to both sets. You would have much better results just running the component set.
autokraftgt
Hemi 6.1
I agree with adrian, run the components only. It’ll sound better.
P
Pollux
Jacksonville, FL
Excellent, that's what I was thinking. I will get back once I finish experimenting with them.
Witch
Hemi 5.7 liter
I would return the 3.5" coax speakers, grab some straight 3 to 4 inch mid-range drivers and mount the tweeters in the sails or A-piller
you can run the tweeters and mid with a passive crossover and run the mid-bass drivers active
adrianp89
Tampa Bay, FL
You are still overlapping significantly.
TomT
SoCal/OC
I would be less inclined to suggest this type of setup to someone not going fully active. A much better option would be a prebuilt, 3 way, component set running off of the supplied crossover. Then later, if the person decides they want more out of it, they can go fully active by adding a DSP and more amp channels.
WadXpress
HEMI
I dont like the dash speakers. To me it's too harsh and doesn't sound good. I would do the components with tweeters in the sail panels
P
Pollux
Jacksonville, FL
TomT can you please elaborate on your suggestion? Your saying “3 way, component set running off the supplied crossover”. The JL audio 6.5 component is a 2 way system, how you’re getting the 3rd way? Are you saying just run the component set in the front stage and a subwoofer for the lows? Thanks!!!
TomT
SoCal/OC
No, I’m saying to start with a three way set.
S0CAL
US Marine Veteran
The Lonestar State
2021 Limited Longhorn CTD HO DRW 4x4
Cummins 6.7L HO
Sound advice (pun intended).
2010 Infantry Vet
Butler pennsylvania
I have the JL 3.5” dash speakers and amplified 6.5” components. Im the 3.5” JLs out and teplacing them with midrange speakers and running a seperate amp to them. The JL 3.5 only handle 25rms, and drown out.
TomT
SoCal/OC
Your situation is highly unusual because of the way you put everything together. Please don’t tell people what to do based on your messed up system.
P
Pollux
Jacksonville, FL
Thanks guys, good advice....I'm thinking on trying the dash speakers with the 6.5" component woofer only both amplified and the 6.5" component set without the dash speakers to see how they sound. That will be temporary until I get, as TomT said, a 3 way set on my way to fully active.....
