Ram TRX Fuel Canister
MurderHemi
Indiana
Has anyone tried or know if the TRX fuel pump canister will at least drop into a ram 1500 classic fuel tank? I have a 17' Ram 1500 I'm getting a Hellcat bottom end installed along with a Hellcat cam and ported Eagle heads. If a TRX canister would drop in that would be a cheaper upgrade to make work.
RedSRT4Me
Scottsdale, Az
2015 CC Sport
Looking at the TRX pump and that lock ring to the gas tank looks the same as the regular 5.7 hemi, meaning the opening should be the same and the length will be gtg. Getting it to work on the 4th gen will be the trickier part. Trickier as in OEM type outcome.
RedSRT4Me
Scottsdale, Az
2015 CC Sport
Shoot if the TRX is on sale for $850 I'd prefer the MMX route for that kind of cost.
Thanks for the research. I know it won’t just plug in but if it will at least mount and drop in that’s the biggest hurtle IMO. Might go ahead and buy a TRX canister.
Get ahold of Rick Tapp at Tapped performance,he knows fuel systems as well as anybody,and will be able to guide you down the right path. If you spring for the TRX basket/pump make sure you use a relay and at the very least 12G wire, 10G would be even better
