Sir I need some assistance, It appears I have the same Pioneer Radio that you installed, I installed it and it did not work ( I purchased the Metra Harness) . I tried putting the stock 3.0 back,( original wiring) that didnt work. I tried reading voltage on the wire because there is no power to the stock deck either. I cant find voltage on the wire harness (original). There is no place or I dont have a radio fuse under the hood either( the manual says if equipped, there is an open space but there was never a fuse there), What could it be , a computer issue, some theft deterent , a actual fuse should be installed there?, Any ideas. I new at this
