Ramesses Stereo Upgrade - Phase 1
Power247
High Point, NC
6.4 HEMI
Heck yeah man!! That will look so much better in the dash. Does it require any modifications to fit in the factory slot?
Sent from my LG 8.3 GPe
Cruizer
Ohio
2010 Sport 4x4 QC
What? You didn't order me one too? lol
Should be sweet. I can't decide on if I want to go aftermarket or not with the head unit. Probably will eventually though cause I'm not a fan of uConnect really.
WhiteExpress
WhiteExpress
Midland, TX
Yea, you have to not the frame, but I already had to do that for the single din and pocket to fit properly.
cableguy_hd
Danville, Va.
2020 Ram 2500 CTD
6.7 Cummings
Which model is your single din? I call crutchfield with a few questions about a radio upgrade and it seemed like I had to spend as much for extra wiring harness as I did for a radio itself...
WhiteExpress
WhiteExpress
Midland, TX
CableGuy: It's the Pioneer DEH-X9600BHS.
If you have the Uconnect 3.0 (no touch screen) it's about $65 for the wiring harness to make it work.
I got the new Double Din AVH-X5600BHS installed:
I of course had to redo the harness entirely. And discovered the factory SXM anntenna connector was failing, so I had to run the aftermarket antenna too. It's above the 3rd light for now. I honestly kind of like it better back there. I can still get signal while at the drive in.
dedogg
Do you lose the steering wheel functions with all after market stereos?
Looks good by the way I eventually want to get rid of the stock unit.
jadocs
Very clean job. Well done on the fab work.
WhiteExpress
WhiteExpress
Midland, TX
You can buy a module to retain the steering wheel controls.
I never had any to retain. :happy107:
Guajabeira
Sir I need some assistance, It appears I have the same Pioneer Radio that you installed, I installed it and it did not work ( I purchased the Metra Harness) . I tried putting the stock 3.0 back,( original wiring) that didnt work. I tried reading voltage on the wire because there is no power to the stock deck either. I cant find voltage on the wire harness (original). There is no place or I dont have a radio fuse under the hood either( the manual says if equipped, there is an open space but there was never a fuse there), What could it be , a computer issue, some theft deterent , a actual fuse should be installed there?, Any ideas. I new at this
Etroze86
Grand Forks ND
There is a fuse under the hood but I believe your HVAC controls wouldn't work either if its blown.
Guajabeira
no problem with the HVAC. only the radio dont power on, neither the new Pioneer or the old 3.0 unit
Etroze86
Grand Forks ND
HHHMMMM there should be a radio fuse and theft deturent usually only locks the head unit not the power going to it.
Caldwell
Philadelphia
looks really good !
this makes me miss having a sound system so bad. I really want to build a solid 300-400w Mid Bass system. I feel you could get some solid thump out of a set of powered 6.5 components, and 6x9 coaxials in the rear, and still be able to rattle the mirrors. I personally love the under seat storage, and would not want to lose that space to a sub.
Guajabeira
I have an 2014 express crew cab, just in case.
Etroze86
Grand Forks ND
They might have changed to to be on a system in the PCM but I really really doubt it with how much trouble they have had in the past with these radios
WhiteExpress
WhiteExpress
Midland, TX
looks really good !
I can't wait for Phase II which will be amplified components. :naughty:
Jus10case
