I have a 2000 Ram 1500, 2wd, with 5.9(360)
Originally while driving there would be moments when I went to give it gas and it just felt like the engine was choking out, one time it happened so I went to full throttle, and after about 2-4 seconds of the choking feeling it kicked down a gear and took off like it should. And once while coming to a normal complete stop it died.
To be noted, it's died a couple times, and when it dies due to this mystery issue, the truck WILL NOT start in neutral, I have to come to a complete stop and put it in park and it will fire up right away without hesitation. When it dies due to the mystery issue, If I put it in neutral and try to start it nothing happens, no clicking or anything.(If I kill the motor myself by turning the ignition off, It will fire up in neutral.)
I could feel it misfiring at start up and I've attached a pic of a couple of the plugs. I changed the Plugs, Wires, Cap and Rotor and since then I haven't felt the choking feeling(doesn't mean its gone just haven't felt it), but while slowing down to make a turn it did die on me(Had to come to a complete stop, put it in park for it to fire up).
I just got the truck and haven't driven it enough to figure out exactly the chain of events that cause the motor to die. Any help or insight would be amazing.
