Random heater changes
Arlucian
Port Angeles, WA
I haven't had this problem for a while, but didn't worry about it cause it only happens on the highway and i've only been doing city driving. But on my journey over here i noticed my heaters switched from whatever setting they were on to defroster when i started lugging (not really lugging just giving it a good bit more gas to get over a hill) then as soon as i crested the hill and eased off it switched back. Its not related to the angle of the truck for any reason, i let off the gas going up a hill on a lonely highway to confirm that, it came back to my regular setting. This is one of the stranger things i've had happen for sure.
Arlucian
Arlucian
Port Angeles, WA
Ah thanks, i did a search but i can't say i tried putting in wild vents... Dafuq is that sheet?
Arlucian
Arlucian
Port Angeles, WA
Fixed it found one of my electrical tape vac fixes failed so i put some heat shrink over the two ends and fixed it that way, probably wont be able to test it for a while but i'm sure itll work. Thanks guys!
