Ratchet Straps & Storage
Three4all
Looking
Looking
How you all organize or store your ratchet straps? I find it is pain to coil them up every time and always come unraveled...and then they gets kinks and take forever to straighten out. Any almost everyone else I know has the same issue...
I look forward to hearing how other people deal with their ratchet straps clusters...
DOAX
never have had a problem with straps wind them up tight and tuck the hook in under the strap as for storage there in i bucket in the bed with a chain and some tow straps
suzukiquadrider
cummins 5.9, 6.6 duramax
i have 2 pegs in my garage wall with a bunge cord going between them with the straps hanging on it.
brandon spiek
MN
hemi
A guy I work with taught me this......wind up, and wrap up the best that you can, then put a couple wraps, and then a couple more wraps of electrical tape on them, unwrap the tape and use it to tape the long loose end to the tightened strap, it keeps it from doing the long tail behind your truck.
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
Hang'm in the trailer. You have to be careful with them ratchets as it is easy to cut the ciculation off using them. ;)
Edit: one day you guys are going to miss my humor.
res1551cue
Scott AFB, IL
I keep mine in my RamBox but I typically wrap the strap around the hook and then I take a rubberband or cable tie (turn it backwards) to tighten them down so all I have to do is take the rubberband or cable tie off and hold onto the non-hook end and let it fall. Seems to work well.
audio1der
Airdrie, Alberta
I only keep 2 ratchet straps in the storage bin in the floor behind the drivers seat, with a stretchy cargo net on top of'em.
I always wind them up and store'em pretty because I find that less aggravating than fighting with them when I need to use them.
Bombdigitty
Currently i have a tote full of them. I plan i putting a storage bar in my ATV trailer to hang them from and keep them neat.
wingnut
Da Thumb
5.9 gas
I toss them all into a f$#%ing milk crate, and pull them out when I need them.
Barracuda556
I just bought a cheap tool bag and threw my 6 or so of em in there and it stays under the rear seat storage.
stokes.greg
I put my ratchet straps in a zip lock bag and that in a cheap tool bag.
Tim7139
Alberta, Canada
2020 Classic ST Crew 4x4
5.7 Hemi w/8 speed 3.92 gears
I used to wrap a large elastic around them and stick them under the back seat. Now I stick them in zip lock bags and store them in the RamBox.
develand
Behind my seat in my regular cab. They ratchets I have are also spring loaded for rolling up, so their is not any excess stuff.
vanalstinew
South Carolina
hemi
With two girls and my wife I always have hair ties lying around. I roll mine up and slap a hair tie on it on throw it in the in-floor storage box.
