ramhunter9
- Joined
- Jun 25, 2010
- Posts
- 24,464
- Reaction score
- 975
- Ram Year
- 2012
- Engine
- P-Star Jeep Wrangler
DBTC is now proud to offer Rough Country / RCX suspension lifts , body lift and much more.
Find them on the site or just PM me your needs. Dont see your lift on the site let me know .. we have it and will list it for ya .
Now proud to offer Rough Country /RCX kits for any make and model ... Some of the hot ones right now for the 09-12 Rams ... If needing a price on a different kit for a different truck 2wd or 4wd shoot me a PM .
RCX Rough Country
2009-2011 4wd Dodge 1500 6" Suspension # number: 329S $1399.95
Front: Front & rear cross-members, driver & passenger side differential brackets, driver & passenger lifted knuckles, driveshaft spacer, sway-bar links, skid plate and strut spacers.
Rear: Lifted coil springs, fixed upper control arms, sway-bar links, brake line brackets, track rod bracket, and bump-stop brackets.
Shocks: (2) Rear Performance 2.2 series shocks.
Notes:
• Kit is not recommended for AWD models.
• TRX models will achieve aproximately 1" of additional
lift. This lift is not recommended for use on the TRX models due to possible CV shaft vibration caused by the additional lift.
Consider our 4" lift system for about 5" of lift or replace the TRX struts with standard struts for use with this system.
Benefits:
• Control arms allow for proper driveshaft angle.
• Control arms feature Clevite brand OEM style rubber bushings.
• Factory tuned coil springs maintain stock ride quality.
• Increased ground clearance.
• Levels front of the vehicle with the rear.
RCX Rough Country
2012 4wd Dodge 1500 6" Suspension # 324S $1339.95
Notes:
Benefits:
RCX 2009-2012 Dodge 1500 1.25" Body Lift $129.95
This Rough Country Body Lift provides a full 1.25" of additional tire clearance, as opposed to the standard 1" provided by most other manufacturers. The 1.25" spacers nest with the factory body mounts keeping the body properly aligned with the frame. This design provides lift while retaining the noise and vibration canceling characteristics of the factory mounts.
Notes:
• Only fits 09-12 Dodge 1500.
Benefits:
• Provides 1.25" of lift opposed to standard 1".
• Includes front & rear bumper brackets.
RCX Rough Country
Notes:
Benefits:
RCX Rough Country
Notes:
Benefits:
Notes:
Benefits:
