Rear .75" or 1" poly spacer, does it exist?
staying_tuned
Poconos
Howdy folks. Another post reminded me that I'd like to lift my rear end (post Bilstein 2.1" up front lift) about .75" or 1" but I'm having a heck of a time finding a poly spacer.
TCG used to carry a 1" poly for the rear but no longer. I see a handful of steel ones and figured I'd reach out to see if anyone knew if poly verssions even exist anymore.
Thanks in advance for any insight!
JB1
Houston, Texas
They make a 3/4” poly bottom spacer
MidTennMtneer
Princeton, WV
Pentastar
Daystar isn’t really “plug and play”. Got mine from Amazon.
It replaces the factory isolator at the top of the coil but there is a cone that comes down from the frame into the isolator, hence into the new Daystar spacer.
The opening in my spacer wasn’t quite big enough for the cone to go into it. Had to shave some away. Started with a manual file then went to a Dremel. Much easier that way.
But still. It needs trimmed. I too got Daystar because I was ready and TGC didn’t have any I guess from being bought out.
Gary2
S Jersey
A rubber spacer for a 1997-2006 Jeep Wrangler ( TJ ) Cherokee (xj) and I forget what year grand Cherokee as they went from straight axle to IFS at some point but are exactly the same size as the rubber spacers sold for the rear of our 1500's . Their are many more sizes to choose from. I ordered a set once from TGC for a 1500 and when it arrived I found it was identical to the assortment of TJ spacers I accumulated through the years. look on ebay , quadrtec most any of the thousand places that sell Jeep Wrangler parts. I have them from 3/8" up to 2" , it don't need to be specifically for a Ram 1500
Ram7081
Hurricane 3.0
A rubber spacer for a 1997-2006 Jeep Wrangler ( TJ ) is exactly the same size as the rubber spacers sold for the rear of our 1500's . Their are many more sizes to choose from. I ordered a set once from TGC for a 1500 and when it arrived I found it was identical to the assortment of TJ spacers I accumulated through the years. look on ebay , quadrtec most any of the thousand places that sell Jeep Wrangler parts. I have them from 3/8" up to 2" , it don't need to be specifically for a Ram 1500
Plug and play for the TJ spacer on Ram 1500?
Thanks
Gary2
S Jersey
Yup they go on the bottom of the spring . I removed the TGC spacer from the 2014. Now its on my tool board with a bunch of TJ spacers I have accumulated . I could not pick out the ones I bought from TGC from the TJ spacers hanging on the board. I had switched them in and out over time experimenting with the rear end height
Ram7081
Hurricane 3.0
ICON coil overs on front set at 2.5". Rear ICON shocks. Rear coils are TTC-1210s (about 1" lift). Spacer added 3/4". On 285/70/17 Yoko tires.
Maybe not be your style, but it didn't turn out bad in my opinion and I like it. The ride is much better than the Bilstein 5100s were.
Front: 39 1/4"
Rear: 40 3/4"
Ram7081
Hurricane 3.0
Thank you Sir!
16WhiteQC
Hudson valley, NY
Front: 39 1/4"
Rear: 40 3/4"
Looks good, what spacer did you end up going with?
Tino lopez
Upstate ny
question. i have a 2016 ram 1500 with bils @ 2.8 up front. i want my truck to sit close to level. ill need to raise the rear a little bit. anybody have poly spacers for sale that actually fit? do the TJ spacers actually fit? .75 or 1 inch spacer for the level look, thanks - Tino
Nixonjgreg
