Rear diff. cover
guntoter
Central Illinois
I’m looking for a finned aluminum differential cover for my 2017 Ram 1500 crew with 6’4” box, Dana anti-slip rear end. It of course has a sway bar and panhard bar with about 3 3/8” from the cover face by the bolts to the panhard. Any suggestions as to what would fit with enough clearance to not strike the bar on bumps, braking or acceleration?
huntergreen
Marine Corps Navy Badge
I know one guy running mag Hy tech. Looks like a tight fit, but there is 0 evidence of contact with the sway bar after a couple years of use.
Pull Ya
Cedar Creek, Tx
I think the only time you might have a problem is if you lower your truck. I have the Mag tech and have had no problem even with the Hellwig sway bar, the truck is a 16 Sports CC 4x4.
guntoter
guntoter
Central Illinois
Thanks for the replies. The Mag Tech was the one I saw that had minimal clearance but if no contact seen then maybe I will consider it further.
Pull Ya
Cedar Creek, Tx
It fits close but I've never had any kind of contact, even with the bed loaded or going over gravel washboard roads.
Jay
geneseedennis
