TGFL2GRAM
I am replacing the seal on my rear door window (quad cab). I suspected leaks, had the panels off already for a stereo upgrade, and decided to refresh the seals.
The upper bracket on the window frame has broken free of the glass frame. Glue gave way. I either stressed it taking it off, or it was already separated.
Is there a recommended glue to re-attach the spring steel bracket? Or just pony up $50 to LMC for a new window, since any repair might not last for long.
If I replace it, any suggestion for gunk/sealer for the gasket to the door metal at the top?
Thx!
2002 2500 HO/6 spd/long bed/Cummins
Thx!
