Funkadelic
My 03 Ram has developed a squeak when going over bumps...definitely coming from the rear suspension somewhere. Doesn't matter if I have the brakes on or off. I replaced shocks last year with KYB's. Jacked up the rear yesterday to let the suspension hang, and didn't notice any loose bolts with shocks, shackle, or leaf springs. Only thing I noticed was the bushing between the ends of each leaf spring looked worn out, so I jammed about a 1/4" thick rubber in it's place to see if that was the cause. Nope. Did notice that the squeak generally goes away after about 10 minutes of driving.
Anyone else had this issue with the Gen 3 Rams? I assume there really isn't too many options, so it's either leaf spring to frame bushings, bushings between springs, or a bad shock? Any other possibilities?
