Rear Spacer Suggestions for Bilstein 5100 x4 Please
DavidRussell
Boise, Idaho
5.7l HEMI
I am new here. I've been looking at a lot of different upgrades for my truck. I just got it about a month ago. I want a small lift. Its for 50k miles so instead of spacers up front I got bilstein 5100s ordered for front and rear. Ordered as a set from 4wheelparts.com
I am going to set them at 2.1" to avoid control arm issues. I do want some rake for towing. Not much. I want to get a 1" spacer for the rear coils. Only option I have found is the spacer set made by Daystar and a lot of people say they don't fit well.
Any other suggestions? I would really rather not buy replacement bilstein coils. I know thats another option for $250. I would like a lower cost option if possible.
Also any problems I should anticipate here?
BOWERSFJ
Uniontown OH
CARiD has a Rancho RS70075 3/4” rear spacer for $46 in stock
DavidRussell
DavidRussell
Boise, Idaho
5.7l HEMI
Are you positive they will fit? They seem to be advertised for Chevy GMC. Can't seem to find reviews from RAM owners.
ram1500rsm
Trabuco Canyon, CA
Where did you read the rear Daystar spacer doesn't fit well ? I ran them for a couple of months while i searched for a set of rear coil springs more in line with my setup. They fitted like a glove, Daystar KC09116BK
With 2" in the front you'll still have a little rear rake so i don't think you need a rear spacer unless you want more factory rake. Rather than rear spacers you should get better rear coil springs. The factory springs suck at handling weight so adding spacers will be more for comestics to lift your butt a bit more.
Have you considered a set of air bags that go inside the rear coil springs,aired up they'll give you some more towing capacity and that bit of rake you want.Just throwing the idea at you to think about
Jtech
Long Island
I have a 1 inch top gun customz rear steel spacer. The installer did not mention any problems with the install and I have had it for 2 years with no problems. I have kings up front for the level.
