Help Support Ram Forum by donating:
Rear Springs/Spacers/Shocks Combo Question
Discussion in 'Lifted' started by rwhjr, Jul 13, 2019.
  1. rwhjr
    rwhjr Senior Member
    32
    492
    286
    May 4, 2018
    maryland
    Ram Year:
    Engine:
    Want more height from the back
    Not a lot....but about 1-1.5” more
    Currently have the bolted in lower spacer that comes with the ProComp stage 1 6” lift
    So I have the 4.5” lower spacer with stock springs.
    Can I safely swap to 1.5” springs to bring my total rear lift up to 6”?
    Then....
    If I can do that what shocks will work? Would the BDS Fox shocks for their 5” rear kit work and not be overextended?
    From there if this setup works I guess I’d just have to get different bumpstops.
    Would like to prevent getting gouged for custom shocks if possible and I’m planning on running the BDS front struts when this upgrade occurs.
    Any help’s greatly appreciated...
  2. rwhjr
    rwhjr Senior Member
    32
    492
    286
    May 4, 2018
    maryland
    Ram Year:
    Engine:
    No one with input on running the 4.5” ProComp rear kit with something like an Icon 1.5” spring?
    Then would the bds Fox shocks work with this?
  3. Graygoose
    Graygoose Diplorable Crumb Collector Supporting Member
    9,031
    3,519
    Nov 21, 2011
    Oklahoma
    Ram Year:
    2019 Ram Classic
    Engine:
    If you could send Fox measurements, they will get you one that fits. Some Ram/Jeep ones are very close.
  4. ram1500rsm
    ram1500rsm Senior Member
    46
    1,824
    1,501
    Jul 24, 2018
    RSM, CA
    Ram Year:
    Engine:
    What rear shocks do you have now ?
    You can use the Icon springs but since you're spending the money on coils anyways why not just get 5" coil springs ?? BDS 034653R i think are the part number for their 5" springs.
    Then any shock for 5-6" wil fit either option , 4.5" spacer with Icon 1.5" springs or with 5" coil springs.
    Fox makes a 2.0 version for BDS, 98224759, 30.05" extended 18.45" compressed, i think you can run this with just 2" bumpstops but please measure.
    Fox 2.0's 985-24-020 will also fit 29.55 extended 18.45 compressed, i bet this are the same Fox 2.0 for BDS except the last have the BDS sticker :)
  5. olyelr
    olyelr Senior Member
    38
    1,261
    837
    Nov 18, 2018
    Kewadin MI
    Ram Year:
    Engine:
    I dont see why it wouldn't work. Aside from longer shocks, you may need adjustable control arms to get the axle back in check. Does your current kit have anything to change the geometry for the control arms (drop brackets, new arms etc.)? Also, I would make sure the bumpstops are proper for the springs/shocks... dont want either of them bottoming out BEFORE the bumpstops are being used.
  6. ram1500rsm
    46
    1,824
    1,501
    Jul 24, 2018
    RSM, CA
    Ram Year:
    Engine:
    Another option for coil springs is to get the part number of your factory Mopar springs and contact Deaver Springs with that info. They can make you coil springs that will provide any lift you want with any spring rate you want based from whathever the factory gave you. Then you can ask for heavier springs rates, linear or progressive rates, desired lift etc etc.
  7. FF1899
    FF1899 Senior Member
    30
    468
    279
    Oct 28, 2018
    Syracuse NY
    Ram Year:
    Engine:
    I got the 3 inch rear kit for sale. Full coil no spacers and everything to go with it
  8. rwhjr
    rwhjr Senior Member
    32
    492
    286
    May 4, 2018
    maryland
    Ram Year:
    Engine:
    I have the ProComp shocks that came with the ProComp stage1 6” lift (not a fan so I’ll be happy to see them go)
    I’d go for the bds 5” rear kit but I’d only get .5” more lift and pay more than just throwing sprints into my current setup since I’d need the whole rear kit from Bds.
    My goal was to add the icon springs and some better rear shocks at the same time but wasn’t sure if that combo would work.
    The ProComp from what I understand comes with one of the better rear control arm relo brackets as far as getting everything squared away after being lifted. I know the off-road guys don’t like the fact they hang lower than factory but like I said, from what I’ve seen, they do a good job at aligning everything?
    Not sure how to check the bds fox shocks if theyll work for 6” of rear lift (when the bds kit comes with 5” rear lift).
    I may look into them and see. But if cost is much more than some Icon 1.5” coils I probably won’t use Deaver.
  9. rwhjr
    rwhjr Senior Member
    32
    492
    286
    May 4, 2018
    maryland
    Ram Year:
    Engine:
    I’m trying to lift the back higher not lower. Appreciate the heads up though.
  10. rwhjr
    rwhjr Senior Member
    32
    492
    286
    May 4, 2018
    maryland
    Ram Year:
    Engine:
    Gotcha. Was just wondering if anyone knew off the top of their head if the bds Fox one’s that come for the 5” rear coils would work with an extra inch of lift or not. Otherwise yeah it would have to be a custom length order...
    Graygoose likes this.
Share This Page
