KimmyLang520
Help! I have a 2020 Ram 1500 and the rear tail lights are not working. I have flashers, brake lights, etc. But no night time tail lights on both sides.
He said his brake light is working and usually that's the same bulb as the tail light, same fuse too I imagine. So I that's why I'm thinking loose wire, bad wire...so hard to tell with a description and not being there. If you take it the mechanics I bet it'll start working the moment you show up.Check fuses,bulbs.
Need more info. Is truck new, if so take to the dealer, Used? Sounds like possible a wire issue for the tail light, if your electrically savvy you can start opening things up and see, if not and you have a warranty I would let the dealer deal.
He said his brake light is working and usually that's the same bulb as the tail light, same fuse too I imagine. So I that's why I'm thinking loose wire, bad wire...so hard to tell with a description and not being there. If you take it the mechanics I bet it'll start working the moment you show up.![]()
