Rear vibration after lift
Big Rammer
Southern Indiana
i put the rough country 3.5” lift on. The rear vibrates like it’s a bad tire or shock. I’ve rechecked everything several times. I’ve put the stock shocks back on and the tires balance out great but the vibration is still there. Anyone had this problem or any ideas? I know a lot of people don’t like rough country but I’ve used rough Country lifts for years with no issues. Any help or ideas is appreciated.
olyelr
Kewadin MI
How was the rear lift achieved? What components were used? Any pinion angle adjustment?
If it is a vibration like you make it sound, I would highly doubt the shocks have anything to do with it.
If you have the factory wheels and tires, toss them on and go for a test drive. Just because a tire shop says the tires are balanced, doesn't mean they cant give you vibrations still.
BravoZulu
MI
Are you running wheel spacers? If so remove them.
After installing a 3” lift I had a noticeable vibration at certain speeds
I put the spacers on same day I had GY Duratracs put on...I thought I got a bad batch of tires or thought tires were unbalanced
took truck back to tire shop..They removed/rebalanced..Drive away and still had the vibration
long story short..I ended up removing the wheel spacers and vibration gone
Back to factory ride after I narrowed it down to spacers
just a thought
olyelr
Kewadin MI
just a thought
maybe your spacers were not installed correctly?
