Sherman Bird
- Joined
- Jun 28, 2019
- Posts
- 3,091
- Reaction score
- 6,695
- Location
- Houston, Texas
- Ram Year
- 1998
- Engine
- 5.2
I just look at the correction on the original pinion gear rear face, then measure the thickness of the original pinion gear thickness, then measure the same on the new one.... calculate which if any shims need to be added to meet the original dimension. 100% works. This saves the whole "find your pinion depth" mystery. This saves the take it apart and reassemble multiple times issue.DILLIGAF. Said it right. Get the tools you don’t have, do your homework and GetRDun.
The reason most shops won’t touch axle rebuilds is it’s time consuming and they’re not setup to do the work correctly. Axle swaps the easy way but what have you learned. I was doing ring/pinion swaps in drag cars starting at age 14 in the 70’s. It’s not beyond you IF you take your time and measure, measure and measure, read the paint, then repeat until you get the correct paint and lash readings. Used gears are the toughest to read. The drive side can be misleading so read the coast side (applies to USED gears)
DANA/AAM - Quickest way is to buy 2 sets of carrier/pinion bearings, grind out the centers of one set so you don’t have to press them on and off. Once you have the readings you want press on the fresh set, then verify. Crush sleeve can be the biggest frustration if you rush it. GM - just extra pinion bearing. 9” - Awe yes - 9” Ford - they make it much more comfortable. Removable 3rd member.
The only time this might not work is if one changes to a different ratio.
