REDLINE OIL long term use ( all redline users come in )
Zoe Saldana
california
6.4l
ok, I just register to this forum just to ask this, I'm gear head and oil nut, my favorite oil is PUP I have been using it for a long time, I did read allot about REDLINE OIL, and the curiosity got the best of me so I try it in my 2020 ram with 20k miles on it, my truck have never have any hemi tick or cold start knock of any sort, but I must say after I switch to RL that motor got smoother and quieter , here is my question to you long time RL users , at what milage you start using the RL and how many miles are on your truck now, what are you high lights low light of using the Rl oil. is there any down side of using redline oil? to the best of my knowledge the RL IS NOT Chrysler certified .
Add some Lubegard to the oil and Miracle Mystery Oil to the gas.
You will question if the engine is on; it is so quiet.
ramffml
ramforum
You don't need to add LG to RL which already has a lot of moly, it's not going to help any.
And I question the wisdom of throwing anything labeled "miracle" in my gas tank but that could just be me.
I switched to redline 5w30 w/royal purple filter at 44300 miles. Clock is at 45800 now.
I don't know if it's the RP filter or the oil that's causing it but the warm idle oil pressure is higher. Never drops below 40 psi.
No codes or lights after 1500 miles.
Redline 5w30 will tend to give you 2 psi higher over 20 weight anything, I would not expect the rp 20-820 to raise psi, now if you had the 10-48 that would give higher psi and also negative psi as in it's cousin filter has thrown some codes. I would guess some oem filters that size have thrown codes, but not enough for mopar to admit an issue, hell they don't even admit hemi tick yet, lol. However, amsoil has more integrity and admits there is an issue with the smaller filter. So far 20-500's and especially 20-820's I have not heard a single issue with restriction in over a decade.
Zoe Saldana
california
6.4l
Who is using RL?
TunaFresh
TN
Has anyone stuck with Redline long term?
My 14 has been on Redline 5W-30 from it's first oil change at roughly 800 miles,and it gets the hell beat out of it at the dragstrip pretty well every week-end in the summer. It has over 600 nitrous dragstrip passes on it,shifting at 6600 rpm,and roughly 80,000 miles now,and it still pumps 218 psi on every cylinder. Truck still runs identical numbers to when it was new and had the cam changed and the nitrous went on it,truck also beats 707/717 horse Hellcats easily through the 1/8th,and if the driver is on the ball they'll just catch it before the lights on the 1/4 mile.
HEMIMANN
Minneapolis, MN
2017 2500 Laramie Crew Cab
Yeah, but do ya tow?! ;-)
