Jonathan Gregory
Dear Ram owners,
I have a 2013 RAM 1500 Laramie Longhorn and I currently have the factory projector headlights in the pickup. I have removed the halogen bulbs and installed LED bulbs but in order for the LED's to fit i had to cut some of the plastic housing away cause I could not find LED's that had a small enough base and water got in the housing and burnt out both LED turn signal bars in the bottom of the headlight. I was wondering if you could somehow put like the reflector headlight assemblies in place of the projection assemblies. Like the quad beam or dual beam? Reason why I am asking this is because the projection assemblies are VERY expensive and I would like to save some money. Please let me know if there is a conversion i can do! It would be much appreciated!! Thank You!
