Remote start issues
JRamFJ
Highland
6.7 diesel
Hello everyone, I need some help, I just deleted my throttle body and I have the check engine light on, which apparently disables the remote start, is there a scan tool or anyway to bypass it to get my remote start back, planning on continue to delete stuff little by little. Thank you for your help in advance.
If whatever you deleted plugged into the electronically, it won't matter if you clear the code it will come right back. If your deleting things, you'll need to find a tuner that can change the programming.
J
JRamFJ
Highland
6.7 diesel
Thank you, I was hopping to do it with a scanner, I have Acces to the snap On modis . I’ll start looking into a tuner .
J
JRamFJ
Highland
6.7 diesel
Any advice for a tuner or tunes to continue to do the delete
You might want to do some digging into who out there is still doing business above or below board. EPA has been cracking down on all the big players and now getting around to the smaller fish in the tuning game. Your best bet is go onto Cummins specific forums.
Noneck
2013 Ram 2500 Laramie. 35's 2 inch level. Raceme. Fully deleted 5 inch FlowPro Exh
Delete time. So as mentioned a lot of stuff has been forced to go underground due to the EPA. I have essentially found 2 warring "factions" if you will for Cummins info. One is igottacummins the other is Cummins forum. Lots of good info on both. I happen to like one over the other but I'll leave that up to you do your research. Just start reading at both, ask questions and see how you like it. Igottacummins will charge you for premium members access which you will need to get in-depth info. This puts a bad taste in some people's mouth. It bothered me initially but a lifetime membership was really not expensive and I was getting good info so I didn't mind chipping in to help keep the lights on. (With the EPA snooping around,this may help to control who is looking too) Hope this helps a little bit.
Sent from my SM-G965U using Tapatalk
Danny V
Savannah, Ga
Does anyone know of a company that sells programmed WIN modules? Mine it goin out, and I do t like taking it to the dealer for a good butt ******, if I can avoid it. TIA
mikep345
