Remove image in rear view mirror?
kabong57
Central IL
2017 3500 SRW 4WD Reg Cab Long Bed
6.4L
Swapped out a RA1 for a RA2 uconnect. used a harness from Mpgrimm2 to divert camera signal from I340 connector to the radio plug which works great. Now have rear view image on the radio screen . When I shift in to reverse, I have an image in the rear view mirror showing camera disconnected. How do I disable this?
Mpgrimm2
Supporting Vendor Navy Badge
SC
2022 Ram 1500 (5th Gen)
5.7L
Remove pin 6 from the i340 connector (Lin Bus CBC 2). That should do the trick. Be sure to tape it up.
M² Mods - From my non Flammable S7!
K
kabong57
Central IL
6.4L
Thanks, wish I knew the proper way to remove the terminals on the I340. Slide the lock plate out and 2 out of 3 of them released very easy with a dental pick. The 3rd one acted like it was glued in there. At least your harness installation worked great.
Mpgrimm2
SC
5.7L
Don't slide the plate out all the way, only about 1/8". I didn't have these pictures before but it sounds like you figured it out for the most part.
