Was able to get everything off and replaced. That was a lot harder than I imagined. The front handles and mirrors are straight forward. The back handles. Remove the door panel, peel back the plastic, with a 5/16 wrench loosen the first nut that is easily accessible, and then undo it the rest of the way with your fingers. Anything dropped can be easily retrieved by peeling back the bottom of the plastic and reaching into the bottom of the door. Next. The pita nut. Undo the top corner bolt with a 10mm socket. Push it back further into the door. Next, place a flash light in the bottom of the door facing up, and then pull up on the handle as if opening the door, and maneuver the wrench to the nut, slide the open end over it, turn to loosen, lift it up just enough to get it off the nut, but not away from the bolt, and then put it down again to turn again. After these you should be able to unscrew it by hand.
