Removing liner spray
Mark5561
Las vegas nevada
Magnum 4.7
Any tips on removing bed liner spray? Tried using a paint removal disc on a angle grinder gets the job done but takes a very long time and eats up the disc quickly.
CantRepeat
2010 2500 Crew Cab
6.7L Cummins stock
Is it Rhino Liner or some off the shelf DIY stuff?
CantRepeat
2010 2500 Crew Cab
6.7L Cummins stock
Try a heat gun to soften it and see if it will peel up? I've seen this done with Rhino lining but not sure how effective it would be on DIY spray in liners. I'd wear a mask while doing it.
madtrucker2016
New York
That is going to be some long and hard job Good luck and let us know how you did
rule18
Admin
Administrator
NY
2017 Rebel
Just curious, why are you removing it?
M
Mark5561
Las vegas nevada
Magnum 4.7
Was only able to take off from the sides since it was very thin layer, I'm taking it off because they did a horrible job and want redue the bed liner spray but professionally
M
Mark5561
Las vegas nevada
Magnum 4.7
Will it leave it bare metal? Did you have difficulty to remove with the wire wheel?
WhiteExpress
Midland, TX
Yes, this will very likely take it down to bare metal. So, I'd keep a can of sealer handy.
M
Mark5561
Las vegas nevada
Magnum 4.7
Not the best idea I've had, 15 mins in I made this much of progress . THICKER THAN I THOUGHT!
2004DRDye
Farmington NM
Cummins 5.9L
Following. I have new to me 2004 work truck with the factory liner I think. Used mainly for hay and gooseneck towing. I was thinking of just sanding it and then applying raptor liner over top. I don’t need it pretty. Good luck on yours. Now just need to find decent masks
Sandevino
North Texas
HEMI 5.7 eTorque
If your goal is to have it professionally redone, then stop messing with it. Take it where you want to have it redone and let the pro’s prep the area. You might pay a little more in prep fees, but they have the tools, know-how and time.
tron67j
Maryland
For about $150 you could throw a bed liner in there and be done. Good luck with your work.
