Replacement Valve Body and Solenoid
La Ramie
Universe
Well, I think the solenoid went bad on my 2013 Ram 1500 with 65RFE.
The transmission goes in Drive and Park but doesn't go in Reverse.
I found there's a TSB related to the Solenoid for this issue.
So now, I'm thinking about replacing/upgrading the Valve body as well.
I came across the below valve bodies. Does anyone have any experience with them?
1- https://www.transmissionpartsdistri...ed-by-sonnax-fits-99-19-dodge-jeep-ram-mitsu/
2- https://worldwidespecialtyparts.com/dodge-65rfe-66rfe-68rfe-valve-body-2009-up/
3- https://transpartsnow.com/65rfe-66rfe-rebuilt-valve-body-with-gray-solenoid-2011-up/
4- https://nextgendiesel.com/products/65rfe-high-performance-valve-body?variant=41427004784813
5- https://nextgendiesel.com/products/65rfe-formula-one-billet-valve-body?variant=41427022905517
HEMIMANN
Minneapolis, MN
2017 2500 Laramie Crew Cab
6.4L HEMI
Go to Rock Auto or Summit Racing and look for the Sonax Valve Body replacement. It's all stiffened up with better-sealed piston rings, etc. They had been on backorder.
You will need to to a transmission re-learn after replacement. This has been validated by a member.
La Ramie
La Ramie
Universe
I checked Summit, and it can't be ordered and no future availability.
I also checked Rock Auto, and it's out of stock.
These 2 are using SONNAX:
06 Dodge
Forest Grove, Oregon
6.7L CTD
Why not get a VB kit and have it installed into your current VB that is unless its fubared sop you need a new one...
DILLIGAF
Canada
smoothee
St. John's, NL
Too late now by the looks of it, but DNJ Components are another outfit who sell upgraded RFE parts
huntergreen
Just makes sense to replace the valve body while your in there IMHO. I would use mopar replacement.
La Ramie
La Ramie
Universe
This is one of the stuffs that it makes sense to upgrade from Mopar’s unit.
