Scarylarry
Just a quick question...if I'm replacing the MDS solenoids w/plugs do I use a MDS or non MDS rebuild set. I'm keeping the VVT timming set.
Unless you're changing the cam to a non-mds cam,you'd use the mds rebuild set.The cam lobes are differant between the non-mds lobes and the mds lobes.Guys have ran the non-mds lifters on the mds lobes,but generally it's not reconmendedJust a quick question...if I'm replacing the MDS solenoids w/plugs do I use a MDS or non MDS rebuild set. I'm keeping the VVT timming set.
sooo, if i.m getting a cam with the kit ,does one hold a performance advantage over the other. Thanks for responding. At this point i can order a MDS or NON mds kit, w/cam included. I am using plugs.
OK, (tuning) I closed my shop in 12 before it was even a thing. Is this a one time programming function. Thanks for the lifter info I was just about to f.. up.
