Retro LED Cargo light install help
mxblaster83
British Columbia, Canada
2014 Ram Sport
HEMI 5.7
just got all the led lights for my truck from retro today
the cargo lights came with 2 (what i think are resistors) blue looking thing
how do i install them?
GlOcKnRaM
Mebane, NC
5.7L V8 Hemi
Sub'd..im also curious about this, im actually buying mine now! Free bump, someone should know the answer! How many bulbs are needed for the cargo light, just one I assume?
mxblaster83
mxblaster83
2014 Ram Sport
HEMI 5.7
they came with 2 bulbs and 2 resistors, im just not a 100% on how to use them
the rest of the lights were easy, im hoping i can just plug them in
cause i don't know how to solder lol
Stangshcky12
Oshkosh, WI
5.9 Cummins
Try them out with out the resistors
I don't see why you would need them
Make sure your doors are shut or you'll be trying to figure out why they stay on dim.... Lol
09SMOKINHEMI
TEXAS
i didn't need any resistors for any of my interior led bulbs
EDIT..... are you referring to the cargo lights on your 3rd brake light? if so, i'm not sure about that one. i replaced my 3rd brake light with one from JJ
mxblaster83
mxblaster83
2014 Ram Sport
HEMI 5.7
its the cargos im having problems with
i dont know how to use the resistors
i put the bulbs in without them but they glow after i turn them off
mxblaster83
mxblaster83
2014 Ram Sport
HEMI 5.7
well i just shoved them in with the bulbs seem to work fine
i left the cargo lights on for 2 mins turned them off and no glow
well shall see if it does the triick ill keep ya posted
Stangshcky12
Oshkosh, WI
5.9 Cummins
My dad and I couldn't figure out why his were glowing a bit
It's cause we had the door open lol
They come on when you open the door but not to full brightness
mxblaster83
mxblaster83
2014 Ram Sport
HEMI 5.7
can anybody chime in on this
i am hoping i did it right by
sticking the resistors in with the bulbs
they dont glow or anything so im thinking its right?
Stangshcky12
Oshkosh, WI
5.9 Cummins
Think your just the only one that's had so much trouble with them
I just changed my dads cargo bulbs and third to LEDs from superbrightled last weekend in his 11
These are the bulbs, no resistors were needed
Pictures might help to
Stangshcky12
Oshkosh, WI
5.9 Cummins
Are you sure it glows all the time? Lol its stupid but my dad and I thought his we're goong to need resistors because they glowed a bit
Turns out it was jist because we were leaving the door open...
jake09
Almost everyone's cargo light will glow dimly with leds without resistors..There is always a small amount of current running through the wires and doesn't affect the stock bulbs but leds take less power to glow..I stuck the exact resistors in the socket with the bulbs like you did. That's fine as long as they run parallel with the socket. You can solder the resistor ends in also.
