- Jan 17, 2016
- 23,816
- 54,818
- 14 Sport
- 5.7
I assume the two black fittings you refer to are the ones seen in post #452.
OK that means that cooled fluid does return to the manifold that sits between the transmission and the heating unit. This fluid must make it into the transmission during HOT conditions through the O-ringed "inflow" tube without being contaminated with warmed fluid from the heating side of the device. I can only guess that this happens because when the system is >180 that bottom orifice at 9 O-clock is closed off and the fluid flow to the heater is now in a static state. Somewhere down flow from the heating element there must be a convergence of fluid coming from the heater and fluid coming from the cooler. When the system is cold the cooler fluid is static because the thermostat is blocking flow to the cooler ( via upper orifice at 6 O-clock ) and allowing flow from the heater ( via lower orifice at 9 O-clock. At this point fluid flow from the heater is active. The reverse occurs when fluid is >180 degrees. That being, fluid flow from the heater is static and fluid flow from the cooler is active.
I don't think that the thermostat has an instantaneous capability so at some intermediate temperatures I suspect the transmission fluid will actually be a mix of warmed and cooled fluid.
Would all that I have said be accurate?
Man you gotta go pull your thermal unit off and take it apart.I think once you have it in your hands it'll be obvious to you how it works.It's not rocket science,but you're sure making it out to be.Of course it's going to mix hot and cold fluid at mid thermostat opening. Look at Khristophers photo and look at the photo's already posted,and it's pretty easy to see how the fluid path works. All it is,is a bypass thermostat with a heat exchanger,when cold the fluid is bypassed through the heat exchanger to be heated,then flows back into the transmission,when hot the thermostat is open closing off the path to the heat exchanger,forcing the fluid to bypass the heat exchanger and directing it to the cooler in the top of the A/C condensor,any thermostat opening in between full closed and full open is going to mix the hot fluid and the cool fluid to some extent,but you have to remember the fluid will always take the path of least resistance,so as soon as the thermostat is off it's seat,it'll be generally favoring the heat exchanger,more then the cooler. Now go crawl under your truck and unbolt your thermal unit,so you have it in your hands,and are actually looking at it,as soon as you're looking at it,in your hand,you'll see exactly how it works,and it'll save a ****load of typing,lol
