Roof Leak
Damon7278
Fort Lauderdale
Going into the truck just a few minutes ago and i see the back of the compartment has a good amount of water coming in from a leak from the rear of the truck, is it from the the third black light? has anyone has this problem before, and again i have a 2014 dodge ram 1500 2 door.
MarshRam
2014 SLT 4x4, 2012 ST
Most likely, that is the first place to start. Take the light off and check the seal. Other than that, I think some guys have had a leak at the puck on the rear.
ScottFL
U.S. Navy Gulf War Vet
2016 RAM 1500 Laramie Longhorn 4X4
HEMI 5.7
Well that just sucks! Make sure you wet vac to get the water out and avoid mold. Good luck but that third brake is the likely candidate.
WadXpress
HEMI
Pretty normal problem. I went to home depot and got rubber weather stripping and cleaned off the foam crap they used.
CHIWS6
Chicago
hemi
Take the 3rd brake light of and replace the seal which you can get from Home Depot
bigdodge
I have a crew but my roof seam was letting water in.
Ravjay12
Definately third brake light. Had the problem myself. Was a good excuse to convince my wife to change to an led one!! Replaced and no more water!
smitty21
Bloomingdale/Bartlett IL
2013 Ram 1500 Bighhorn
I had a water leak from the sharkfin antenna. used a little black flex seal and sealed it right up.
rotwiler
Washington
Seen some stains on my 13s headliner so I bought a $30 blacked out led 3rd brake light, zero issues and been on like 4 months now.
