craigripley
- Feb 27, 2015
- 3
- 2
- Location
- Medicine Hat, AB
- 2014
- Hemi 5.7
Hey all,
Got a bit of a mystery going on with my 2014 Ram 1500 5.7L, just started noticing it about 2 weeks ago and haven't had any luck fixing it.
On the first start of the morning or after the truck has sat for about 4 hours or more, the truck starts strong like normal, but then idles poorly to the point of sounding like its about to stall for about 10 seconds, and then everything smooths out and goes back to normal. If I give it some gas while its struggling, it no longer chugs away.
Engine is the 5.7L, has 93,000km on it and running Redline 5W20 or 5W30 in it and have been for a while now. Engine has a Green Racing stage 2.5 cam / springs (factory lifters) done about 25,000km ago, ARH Long tubes, S&B air intake, ATI dampener, e-fan, etc.
Since it's started I've replaced/checked the following since this started:
New Battery
New Spark plugs (all looked normal coming out)
Compression check while doing plugs - All cylinders 210-225psi
New PCV valve
Removed fuel rail/injectors, checked for leakage, found none.
Cleaned air filter
Cleaned throttle body
Not sure what my next step should be...just wondering if the community has any ideas or experience with something similar. I'm about to pull the valve covers I think and have a look, although with good compression I'm not sure if I'll find anything there. Potentially an intake leak or vacuum leak? I've looked for any vacuum leaks and haven't found anything out of place. Any sensors I should maybe replace? Crank/cam position, MAP, etc? No codes present or stored.
Any ideas are appreciated! Thanks!
New Battery
New PCV valve
Cleaned air filter
