Rough idle
ptuttle78
What would cause truck to shake and idle rough?
bhonshell37
Washington
Bad fuel filter, misfire, bad grounding wire
Elevated 2013
Huntley, IL
Bad fuel pump/not enough gas getting to the engine, misfiring on several cylinders depending on how bad it’s shaking. Do you have a check engine light on? If it’s flashing you need to stop driving it.
Fitzreefer
Harleysville, PA
2013 Power Wagon
Hemi 5.7 L
Other items besides what was already mentioned. Mass air flow sensor (MAF) replaced, throttle body need cleaning? When was the last time spark plugs were replaced? If you have the 5.7 L Hemi it has 16 plugs (2 per cylinder), supposed to be changed every 30 K miles. If your truck is aged, change the plug wires.
Sent from my Moto Z (2) using Tapatalk
P
ptuttle78
Had check engine light. Misfire on cylinder 7. Had quarter tank. Filled it up, then it stopped and the light went off
Elevated 2013
Huntley, IL
Interesting. That’s like the exact opposite of a canister purge valve sticking closed as that usually happens after you fill up and doesn’t go away until after you go through some gas. I wonder if it was sticking open and not letting enough pressure build up?? But that wouldn’t cause a misfire. Can you see any history codes??
Burla
2010 Hemi Reg Cab 4x4
99% you need a new cam and lifters. How many miles, and what was the lubrication habits? OCI and oil brand and weight? Ten guys will say I'm wrong like everytime, and chances are this is the result. Is it mostly low rpm and idle shake? Trust me I take no pleasure in delivering bad news, it is sad we all have to deal with this. You might be .01% as in it was bad gas, I hope so.
