running boards
dlarracey1
maine
can anyone tell me if the on my ram bighorn 2020 have the bolts from factory
wrench78
Air Force Law Enforcement
SE PA
2022 2500 Laramie
6.4L
The bolts will come with whatever steps you purchase. What you have under the body is holes where you place the bolts/wing nuts and or nut rivets already in place to accept the bolt. they may be covered by a piece of painted over tape.
Robert15801
Herndon, vA
Cummins HO
It is usually just hex holes underneath that you put squash nuts (rivets)in. Easy to determine with a quick look underneath.
There's an even chance the holes will already be there and threaded. Mine were.
These two are the correct answers. Mine had the hex holes, so I used hardware that came with the kit that had a backing plate with one stud and one threaded hole. I thought about using squash nuts, but I kind of liked the idea of the backing plate for extra strength.
diymirage
Banned
I have a set on my Ram, not sure what brand they are, but they mount to the cab/frame mounts
Those are the most solid running boards I've ever had, I'd looks for a set that mounts like them
blue ghost
Pennsylvania
2013 Ram 1500 sport
I used the rivnuts, and they have been on since 2013 without a problem. A lady even drove into the side of my vehicle and they held up.
