Running hot
Gigi
Mississauga, Ont, Canada
Noticed lately in the cold weather that it’s running hot. It’s normally around 95, but will get upto 110-125. The fan will continuously run for over 10-20 mins, then decide to cool down. Anyone else experiencing this. Any thing to worry about?.
HammerHead
USMC 0313
Georgia/Florida
2019 4Runner
2011 Hemi; I'd change the thermostat and coolant. How many miles on it? When was the last coolant service?
14Tradesman
Kentuckiana
I second the thermostat. Fluid change cant hurt either.
Burla
2010 Hemi Reg Cab 4x4
First, what are you talking about? And those temps aren't hot, must be misprint.
Burla
Even at that what is he talking about, oil, tranny, coolant? If it is coolant or tranny (2011 6 speed), then I'd say it is high, if not then it's normal if it's just oil.
2011 HOAT way over due if not serviced yet.
14Tradesman
Kentuckiana
He says fan so Id say coolant.
Burla
Could be the mix is off, too much coolant. Could be crud in the system, rmi 25 time.
HammerHead
USMC 0313
Georgia/Florida
2019 4Runner
He's in Canada so I figured he was using Celsius. Running 257F in Canadian cold is way to high.
OP are you towing when you see those high temps?
joshuaeb09
Medina County, TX
Sounds like centigrade read outs. 95 would be right at 203 and 125 would be something like 260. Sounds like a bad stat or some major cloggage to me. I would swap the stat and flush the cooling system.
Burla
If it's crud or goo the problem is coolants don't have detergents. So unlike engine oil that when you change it cleans the system, changing coolant does nothing to dislodge crud. If the 2011 never had a HOAT replacement with high mileage, I'd say it could be the issue. And yeah 260f is way too high. Sorry OP forgive my Americaness.
Gigi
Gigi
It’s got 220929 km
I’ve bought it new, it’s the original thermostat.....
Yes I’ve noticed it when towing my 16ft enclosed trailer.
joshuaeb09
Medina County, TX
That's what emulsifiers are for and a few good straight water flushes. Short of ripping the system apart if it is crud that's about all you can do.
https://www.solidstart.com/SDS/T508_SDS.pdf
