SD Card Keeps Copying Songs?
RocketFoot
Southwestern PA
I started with about 200 songs on a 4gb SD card and plugged it into my truck. Now, it seems like every time I change source to SD, there are dozens of songs copied on the card...it is over 400 tracks now! I'm not sure if this is an issue with the SD card or something the 8.4AN is doing? Has anyone ever seen anything like this happen?
NYCruiser
Yonkers, NY
Are they different songs than you had, or just duplicate copies of what was there?
RocketFoot
RocketFoot
Southwestern PA
Duplicates...sometimes up to 20 of the same song all in a row. I know they weren't on there originally. I still need to pull the card and examine the contents on a PC to see what is going on.
NYCruiser
Yonkers, NY
Yeah. It might just be the way the truck indexes the card. Are you copying the songs to the radio, or streaming them off the card. I'll bet the card looks normal in a PC.
I had a MyGig nav system in my Jeep that used to copy my songs to its hard drive everytime I started the truck if I left it connected. Then it would look like I had multiple copies of the songs everytime I scrolled thru them.
Pandemo
Copy Songs in SD-Card
Hello.
I know, this thread ist a little older but here is my solution:
First: Do NOT try do Hard-Reset the UConnect-System.
My problem was also, that the UConnect-System doubles and triples Songs.
Thats, because UConnect stores some information about the Card an Song-Files.
My Solution:
Fist I formatted the SD Card (Intenso 32GB; Format Fat32).
ATTENTION: Do not use Quick-Format. I know i takes a little Time to format a SD-Card with 32GB oder larger but (in my case) it was necessary.
AND (and i think thats the point) Rename your Card. (The name of my card was by default "intenso" and i renamed it into "RAM".
And it worked.
When you later add some Songs there is no Problem.
When you later remove some Songs it would be the best, to try this procedure again to avoid the same problem.
I hope this solution will also work on your System.
Greetings from Austria.
Pandemo
