dmccabe
I replaced my seat belts to a different color third party (blue) to match my new custom blue carpet. The new seat belts came with a new buckle, that has a grey connector with TWO wires.
This is the 3rd party seat belt connector:
I know this connector will not fit into any Dodge connector, I will solder the two wires. I just don't know WHERE the two wires go in the Dodge wire harness
I have a 2005 Dodge RAM 1500 Tradesman and if I look under the driver's seat there are THREE Dodge grey connectors. One is for the power, and I soldered all the wires to get the powered seats to work. (I installed 2010 leather powered seats to replace my 2005 manual seats). The powered seats work fine, all wired in, I tapped a 12v line. Not sure what the other two grey connectors are, but they HAVE to be the seat belt in one of these three connectors.
I just need to hook up the two wires for the seat belt, so I don't get the dash light and the chime.
Is this the correct Dodge connector under the driver's seat? And it has three wires, not two.
Here is one the grey Dodge connectors under the seat:
[UPDATE: Is this the MEMORY SEAT MODULE?]
Note the three wires, not two.
Is this the wrong connector for seat belts? What is this connector?
Here are the other TWO connectors. The one of the left is where I tapped into power for the seats. The grey connector on the right, I have no idea what that is for:
These last two connectors, the one of the left is the POWER SEAT MODULE, the one on the right not sure, is it the POWER HEAT MODULE?
Where does the TWO seal belt buckle wires go to???????
... any help appreciated.
