seat swap
lonsloo
Lakeport cal.
I found a 2019 ram 1500 power seat I would like to put in my ram 2017 1500 has any buddy tried this? will the boults holes line up? thanks for any input
If the seat from the '19 seat is out of a Classic version(Gen4 DS body) it should bolt and plug right in.
If the '19 is Gen5 DT body truck it may not bolt in directly and the wiring for the power seat and airbags may not be the same
Ricks Ram
It will work as long as your truck has the correct wiring. If your 17 is an Express/Tradesman or in some cases an SLT it will not have the constant 12v power for the seat adjust to the connector. If your truck is a Bighorn up trim level it should have the correct wiring. Look at your trucks driver's side yellow seat connector. If you have a solid red wire in pin#1 your truck has the correct power wire. If it doesn't you will need to run a fused constant 12v power source to the connector and it should work fine.
Sent from my SM-G981U1 using Tapatalk
tnctx02
2017 RAM SLT
3.6L Pentastar V6
Found a great deal on a set 2021 classic seats. Any know if they will bolt into a 4th gen truck?
