Security Bypass Cable needed
rule18
Admin
NY
2017 Rebel
authorized vendors?
authorized by who?
i dont know where you're from, but i live in what is supposed to be a free market economy
and that means that if a vendors truly makes a superior product, they will do well
did you know that with any email program, you can set an "out of office" message?
no delayed response there, an email comes in, and one goes out
simple as that, but i guess not simple enough for the good people at koadtech
ass far as complaining about the color of a cable, thats like me complaining that koadtech' logo looks like a bull violating a truck
on a side note, the 8+12 cable i have is also red, but it sits behind a panel and no one sees it
now, in the off, off, off chance id need a stealership to work on anything i own, it would take a whopping 3 minutes of my time to disconnect the cable and no one will ever know
maybe im cheap, but i think 3 minutes of my time is worth the 100 odd dollars that i saved over using koadtech
(now, i cant be sure about the price difference, because, well they never bothered to respond to my inquiries so i have no idea exactly how overpriced their lil cables are )
I'm guessing he meant our Preferred Vendors here on the Forum. https://www.ramforum.com/categories/preferred-vendors.80/
RamDiver
Marlborough, Ontario Canada
2021 DS
Finally received kaodtech bypass. I was able to change fuel tank capacity to match the titan 50g I installed. Range miles seems updated but fuel gauge was on 7/8 tank and took 32g at fuel up. I guess the gauge doesn’t correct.
Much bigger problem….changed tire size to match the 35’s i put on. Change was received but Now I have no Speedo, park sensors, ABS, 4x4 system unavailable and several other warnings. Much help would be truly appreciated. Thanks in advance
Did you make a backup copy of the BCM settings before making any changes?
And did you log each individual change with the current setting and the new updated setting?
N
New2Ram24
Louisiana
6.7 HO
Found any exception video online. All issues corrected except the fuel gauge
