Selectable Tire Fill
P B Casterlin
NEPA
2019 3500 Dually
6.7 Cummins HO
New to me 2019 Ram 3500 Dually with Selectable Tire Fill Alert. I was trying to adjust the pressure in my front tires today. I have the STFA enabled in the settings menu, setpoints 75 Front 65 Rears. When I got the truck home I noticed the fronts were wearing on the outside edges. The pressure was only 55 psi i both fronts. I added air in the driver's side front and the horn beeped once when I reached the 75 psi setpoint. I tried the passenger side but couldn't get the hoen to beep when I reached 75 psi. It's probably something I'm not doing or don't have enabled but the owners manual isn't much help.
Anybody familiar with this system?
KeithP
Hemi 5.7 VVT
Your issue is more than likely the TPMS monitors in your tires, not the truck.
Buy a good air gauge, leave the truck turned off when inflating tires, never look at the TPMS readings unless it gives you a low tire warning.
2020PW
East coast
The wearing of the out side edge of the tire is an alignment issue. Don’t use factory specs for the alignment, find a good tire shop to do it.
