Service 4wd scan tool
CurtLicht
Hey everyone,
I have a 2013 dodge ram 1500 and I am looking for a diagnostic scan tool that will be able to scan my service 4wd code on my dash. I currently have a topdon artilink 600 that can't read the code.
Curious if anyone has any recommendations on which to get and which to stay away from.
Thanks.
I am not positive, but believe Brainsmobile has a 2013 Ram Tradesman, he made this video
This is the 2019 way to check things
C
CurtLicht
I found this app called https://www.alfaobd.com/index.html
And with it and my cheap $20 obd2 Bluetooth scanner I was able to read the code C1464. With that knowledge I was able to track down the problem to a localized area. I traced the wires from my front axle actuator and was able to find a broke wire which I repaired and now my service 4wd light is gone.
smoothee
St. John's, NL
Nice! JScan is another pretty good app for tracking faults, live data, etc.
Jeepwalker
WI
2012 Reg Cab, 4x4
There's more AlfaOBD info in the Tech and DYI sections (of 4th gen forums)
DILLIGAF
Canadian Forces
Canada
I am looking to read my service 4wd light as well
Alpha ODB
This is my last fault code I got. Good thing I keep all my old working parts when I swap out for new ones. Took longer to put the truck on the lift than swapping out sensors... lol...
352531830_6916716605009545_2172055696743815753_n.jpg351714821_114823334958202_3866649282629046658_n.jpg
chri5k
USA
Diesel
I bet that thing pulled to the right with the left front wheel going 255km/h and the right front only doing 60km/h.
DILLIGAF
Canadian Forces
Canada
Just a little bit :eek: Still weird that the sensor only lasted 4 years.
