She's almost done!
reddevil78
5.7 he I
Well as you all know I said my truck would be lifted 2 days ago the shops a little backed up so delivery date is tomorrow! The specs are
4" zone lift with a 2.5 level on the front.
35 12.50 Toyo open country m/t's on stock sport rims.
I went with a sct x4 tuner looked nice and simple to use.
Now we have a problem I don't have pics of my personal truck but I did find a picture of a truck on here that looks exactly how mine looks right now I'll post it after the thread. My problem is I'm rubbing on the upper control arms again on the front end so I know spacers won't work now so maybe an adapter.
I want to go the least length of adapter I can go with because I want her to look more tall than stocky. I want some tire lip out also, but it's mostly because my tire wall is stuck on the upper control arm. So my question to y'all what size adapter should I run with?
reddevil78
reddevil78
5.7 he I
This is how she looks right now more or less tired stick out a bit more tho
Mopar1987
Livingston TX
From what I've read, 1.5" is the minimum if you don't want to cut your factory wheel studs.
Reo Cook
Houston
5.7L HEMI
I have a pair of 2" ones I pulled off this morning from the front of mine. Let me know if you want them and I'm sure we can work something out
My fronts just stuck out a bit too far for me when combined with my spindles.
reddevil78
reddevil78
5.7 he I
1,5" sounds reasonable to me and no no I want no cutting of anything it's whatever I can fit on there without making any other adjustments. Thanks for that info tho.
Stlram21
St. Charles, MO
I tried to fit 1.5" on my 12' and the studs were still pertruding past the spacer. Measure your studs first before buying or you'll run into what I did and have to reorder because you don't want to trim your studs.
fordtech90
Jonesboro, La 71251
What brand are they? I may want them.
