Should I throw it on?
Magnum5.9
01 ram 1500 4x4
Magnum 5.9
In my quest to replace my leaking non-check valve tranny line, autozone could only get the check-valve line and now I'm stuck with the new check-valve line(the line that isn't leaking).
So long story short I'm just going to cut out the flexible leaking part on the non-check-valve line and replace it with a new generic hydrologic line and clamps. But my question is: should I replace check valve line with the new check valve line that I got from autozone since I already have it? Or since it's not broken or leaking, just leave it as is and return it to autozone?
After reading the delete check valve mod, im not sure if I want to do that since I live in a cold climate... so should I throw on the new check valve tranny line in hopes that the new check valve won't get stuck and starve my tranny of fluid like some guys on here have had issues with?
Thanks guys you're a big help!
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
Fun thing about the check valve is that it clogs up. It doesn't effect the transmission's ability to warm up, only bypassing the radiator cooler will.
M
Magnum5.9
01 ram 1500 4x4
Magnum 5.9
I didnt bother explaining what the check valve does because i already wrote a novel on my first post...
but my question is basically should I leave the OEM check valve on or replace it with the new check-value line that autozone gave me? My thinking is that the new one will either last longer and potentially not clog up as soon?
Stegs
1998 Dodge Ram 1500 4x4
5.2L 318 C.I.
i removed my check valve completely
added a trans cooler while i was at it and I live in michigan, cold winters here
as im writing this my phone says its 8 degrees outside
I drove my truck for 2 winters with the valve gone and trans cooler.....trans does take longer to warm up...but im pretty easy on the old girl anyway
Now my truck sits all winter inside, only driven in summer months so i cant comment on longevity, but the 2 winters i drove it i had no issues....just took the trans a long time to warm up
My opinion, get rid of the valve all together...one less thing to worry about..
2NDGENGASSER
360 Magnum
where at in Michigan if I can ask? :p
2NDGENGASSER
360 Magnum
Living in lakeview at the moment and working in howard city at parts plus. Just applied for a job in grand rapids as well :) good to know that there are ram fans closer than i thought! Lol
2NDGENGASSER
360 Magnum
Sorry for the all caps haha im not yelling, just at work and switching in between screens
No members online now.
Mr_relax
