SOS...12" Screen died, froze, whatever...
UTAHPWRWGN
Hurricane, UT
6.4L Hemi
Is there any way to reset this thing is it ***** borked? Totally unresponsive with "shattered" random graphics. Even the buttons on the sides are dead even though there's still power to the unit.
14 Lonestar
Are you still under warranty?, if so have the dealer fix it.
olyelr
Kewadin MI
Hmmm. Maybe try unhooking battery for a bit.
stevenP
northern Indiana
2022 2500 Longhorn
6.7L Cummins
If un-hooking the battery doesnt fix it. You will need to see the dealer.
MADDOG
Out Exploring Arizona
You can reset it by pulling it from the dash and disconnecting it completely from the truck. Give it at least 60 minutes before you reinstall it so that it totally resets.
If that doesn't work then, yeah, it's totally borked.
Docwagon1776
Midwest
Dunno if it will do anything or not, but it's free and easy to try:
Hold the power button in for 20 seconds to force a hard restart.
If it doesn't reset, try the same but with the power button and the tuner button held in. Maybe Google your specific year and model to see, as it apparently varies.
Adventurebound
Las Vegas
I had the same issue that got progressively worse, started out by freezing, then moved to pixielating, then would do some random high pitched buzzing through the speakers. Only way to temporarily reset was to turn the truck off. All the fixes mentioned above will not work. How do I know? Three new radios later (yes that is correct THREE radios) I tried all the easy fixes first.
Hopefully you have warranty. The first radio that was replaced I waited months for, supposedly backordered. Interestingly enough it was also defective but with different symptoms. The second radio, had the same issues as the factory radio. Finally on my third one, technically fourth including the factory radio, and I have been trouble free for over a year....fingers crossed.
One peice of advise. As usual when I would bring the truck in they couldn't replicate the issue, as it was random. I took a video with my phone next time it happened and went back and showed the service director. He had the tech come out and watch and that was proof enough they needed for a warranty claim.
A trip to the dealer is in your cards....
Goodie1990
