Spacer question
MagSport
South Carolina
Those are for the rear leaf pack bud, not the front springs. If you want to add lift to the front you have to get coil spring spacers like these
http://m.ebay.com/itm/280911215717
And if you decide to go more than 2.5 inches, be sure to get a track bar relocation bracket, otherwise the truck will dog leg going down the road and you may run into issues with death wobble.
Edit: if you do decide to go this route, the spacers go above the coil spring, not under. Putting the spacers underneath the coil spring will hinder stability and make the truck extremely dangerous to drive.
Johnn123
Ontario
2" Lift Leveling Kit 94 13 Dodge RAM 2500 3500 4x4 4WD Fits 1500 Mega Cab | eBay
He is a 2wd, so I found out a bit ago aha. No track bar on the 2wd. You are correct so far as I understand though, need spring spacers to lift the front of 2wd. Spring spacers for sure go on top.
MagSport
South Carolina
Oops lol, I feel like I new that but for some reason it never occurred to me.
