Spark knock after 1.7HS upgrade
directconnection189
WV
5.9L
I just recently installed my HS 1.7 rockers and have about 300 miles on them and know I'm experiencing a spark knock at a load going up hill, I have fixed the plenum already do I need to regap my plugs to a different spec I am also using super chips 91 tune
talon6
ohio
2002 QCSB 4X4
supercharged 5.9
i have never heard of this issue with them before. and i know a few that have installed them.
sounds like bad gas. are you running atleast 91 octane? 93 would be better.
and i have always ran a little cooler plug. that always helps with pinging.
talon6
ohio
2002 QCSB 4X4
supercharged 5.9
shell is usually good gas. so not for sure there. you could try some autolite 3923 plugs. they r pretty cheap and are colder.
hemifever
Apex, NC
Might be time to run a can of sea foam through there if you've never done that since the plenum was fixed.
directconnection189
directconnection189
WV
5.9L
I ran 44k since then........... I picked up some plugs, cap and button to see if that helps
talon6
ohio
2002 QCSB 4X4
supercharged 5.9
get it figured out?
directconnection189
directconnection189
WV
5.9L
Haven't had to much time to work on it or be on the forum here been on the road a lot and gf just hit a deer
directconnection189
directconnection189
WV
5.9L
Well after changing plugs, cap&button and wires and about 1200 miles it just stopped outta nowhere
talon6
ohio
2002 QCSB 4X4
supercharged 5.9
forgot bout this till i seen your post on headers. glad it all worked out.
talon6
ohio
2002 QCSB 4X4
supercharged 5.9
nope. chewed the crap out of the belt. took it back off.
alphaprojects
