Speaker Upgrade with amp suggestions?
Danny Smith
South Carolina
5.7L HEMI
Looking to upgrade the speakers in my 2016 Ram 1500 SLT and add an amp to them to get some better sound. Already have a set of subs under the back seat and need a little help from the speakers to even out the sound. Any speakers and amp suggestions that work and sound good?
Matts175
I can help you with one part....
These sound 1000x better than the factory ones. I just put a set of these in last Friday. With just those 2 and no amp, my stereo sounds way clearer and less muffled.
https://www.crutchfield.com/p_206CSC354/Kicker-43CSC354.html
Be sure to add a 4 ohm resistor though, as the factory ones are 8 ohm and the speakers I linked to are 4 ohm. If you don't, they will over power everything else.
How to: https://www.ramforum.com/threads/how-to-4-ohm-resistor-upgrade-for-aftermarket-dash-speakers.125742/
If it would ever warm up outside, I could change the 4 door speakers too. Don't want to crack anything in the cold.
WilliamS
Tampa FL
Door 6x9s are plenty stout for basic speakers on midrange duty, get good/great 3.5s in the dash and add the 4ohm resistor to keep the system balanced (as all things should be).
Subwoofers I have 2 Alpine 12's in a ported box running 1500 watts, throwing down the pain when my baby isnt in there with me. The door speakers blend amazingly without an amp. Not everyone needs that kind of power, but I do!
TomT
SoCal/OC
What did you use to get the signal for your sub amp? If you already have a multi-channel LOC then it makes it much easier to recommend items.
TomT
SoCal/OC
I have an AudioControl LC2i for two channel output for my subs
Cool, so you're already familiar with tapping into the factory wiring to get signal. Are you just looking to do a simple amp plus six speakers upgrade or are you wanting to add DSP control and components, etc.?
Danny Smith
Danny Smith
South Carolina
5.7L HEMI
I just want to replace the current speakers and add an amp to them not add anything
TomT
SoCal/OC
In that case, the Kickers mentioned above are a nice option. You have six speakers total (the front two are wired together on each side). Sometimes putting both the door and dash on a singe amp channel can make the dash speakers way too loud compared to the doors. You can offset that using resistors somewhat and play with the load on each speaker.
Another way, which I like better, is to use a six channel amp and run new wires to each speaker. That way you can use the gain controls in the amp to balance the output. Even better, it makes it very easy to decide to add a small DSP and get full control over everything.
As far as speaker brands, I am a huge fan of Audiofrog. Of course, they come in at a higher price point than the usual Kicker, Alpine, Infinity stuff. Do you have a budget in mind for everything?
Danny Smith
Danny Smith
South Carolina
5.7L HEMI
No budget on this but of course U don’t wanna spend the most on it you know?
TomT
SoCal/OC
I definitely get it. I’m one of those idiots who like the higher end stuff so I try to be careful before recommending $3,000 worth of gear to someone who is just looking to spend a few hundred.
