speedo issue
bigtigga84
dela....where?
Damn thing keeps riding up my ass..... oops sorry wrong speedo. So on the highway yesterday there was a radar sign that tells you how fast your going. Needle was at 65 with cruise on, but the sign said 60. Had a friend do a test a little later and im 4-5 mph off. Have stocker 33's and recalibrate with the supechips. Not really understanding what the issue is. Which way do I need to go to get the speedo dialed in closer to actual speed?
TheSatinPumpkin
Robles Junction/Three Points AZ
2004 Dodge Ram
5.7L
Do you just enter the tire size that's on the sidewall or did you manually measure the rear tire(s) height? Also the tire OD will go lower as the tread gets increased wear.
bigtigga84
bigtigga84
dela....where?
Its just has inches not the crap 275 yadda yadda yadda. So actually measuring the tires is what I need to do?
BlackedOutHemi
DFW, Texas
2012 & 2012
5.7L HEMI & 6.7L Cummins
When I put mine on the dyno with 31" tires I was about 8 mph off on the speedo. Since I was driving around on them, I used the diablo to adjust the speedo, and put in the size of the tire on the sidewall. When I finished, we ran it again, and it was about 4-5 MPH off the speedo. So I'd measure them yourself.
quietpeen
2021 TRX
Hellcat
yea with superchips i think the actual number you need to put in for the stock crapyears is 31.5
03MopaRamman
RAM SPORT / 18 SRT
Southern Alberta
2019 (2003 Forgottens SOLD and 2014 SOLD)
Hemi 5.7 (392 Hemi) 86 Ford .308 HO Roller
That should be pretty close (what Butch says) . Measuring Tape of tire on the Truck is usually bang on. A good way to confirm is with your GPS and from there make the tire bigger or smaller (can't remember which way. I beleive smaller actual size will lower your speedo). I had to tweak mine by .25 " to get it bang on. My next Data log will be even more acurate and hopefully break into the High 5's.
nussdawg395
PA
5.9 Magnum
Ya know I got 35s on my ram and I changed tire size with my superchips and it threw my speedo way off. So I put it back to stock and checked with gps and one of those signs and I was dead on. Weird but true.
bigtigga84
bigtigga84
dela....where?
Changed to 31.5 and its dead on now according to the gps app for my phone. Gonna check a little later today with a friends gps to make sure. Thanks for the help guys.
