Springs and questions
Jeff Krawczyk
Massachusetts
Spring is almost here in the northeast and I'm going to be changing my front and rear springs out on my 14 1500 with a 6"lift...would like to be able to remove the rear spacer and just add a larger spring, I have seen guys post pics of a 5" lift spring for the rear so was thinking of getting a set and remove the spacer, that should work? Yes/no...also would like to replace the front spring and add a set of the billstiens to remove the preload spacer, which should work yes/no...and anyone have a place to purchase said springs...thanks
JB1
Houston, Texas
What lift kit do you have?
