Spyder LED taillights and Diesel LED backup bulbs
AE5548
NH
Been wanting to upgrade the tail lights for a while and finally pulled the trigger. These aren’t the standard Spyder LED tail lights, these are the “neon tube” version which I think look a lot nicer. And I figured why not upgrade the reverse lights at the same time. I was being bombarded with ads for the Diesel LEDs and I figured why not. They are no joke. They are by far the brightest reverse lights in a standard housing I have ever seen. They’re like headlights. I also grabbed their LED license plate lights.
The install was super easy. Just plug the cable coming out of the back of the new tail lights into the original socket and then install the socket in the new housing. That’s it. Back up lightbulbs work the same way. The only difference is the back up light bulbs use a rubber grommet to mount them to allow you infinite adjustability to get the angle right. So I just wrapped the socket plug with electrical tape for moisture proofing.
JB1
Houston, Texas
Those tails look very bright. How bright are they during the day without the headlights on?
AE5548
AE5548
NH
Do you mean just as Brake lights? I can take a pic.
Ohio5pt7
Ohio
Had these on my truck with the smoked lens. Busted one ordered another set lol. With the smoked lens reverse light suck but it was stock may upgrade when the new ones get here
Sent from my SAMSUNG-SM-G891A using Tapatalk all grammar errors brought you by fat fingers and auto correct.
AE5548
AE5548
NH
Did you get any error messages or hyper flashing?
Nope. They come with built in resistors. Function just like stock. Didn't even have to change the settings in AlfaOBD.
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
As bright as if not brighter than the factory LEDs, the tube light running portion is super bright too. They are the best OEM looking tails in my opinion.
Reactions: JB1
FmsTgun
valparaiso, in
shadowhawk
Southeast WI
hemi 5.7 with I2 tune
You must have gotten lucky then. I have spyder LED tails versions for my LED equipped sport and I get errors and hyperflash on the turn signals.
Ohio5pt7
Ohio
Are you sure you got the right version? Sure you did but they may have sent you the wrong ones?
shadowhawk
Southeast WI
I went thru 2 version, and confirmed with them over the phone that I bought the proper LED versions for my truck.
shadowhawk
Southeast WI
yup- all over that up and down alpha
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
Do you have a link to what you purchased? There are more than one type that look similar.
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
shadowhawk
Southeast WI
Herefishy
